Any Ideas??
Harndog
86
Well got the trans figured out it working great now but headlights was out replaced Dimmer no go then replaced the headlight switch head lights work. I then notice that the blinker lights in the dash seem to be on solid. SO I got to looking around and see smoke coming from the top of the steering column. I unhooked the battery and took a break to cool down. Any ideas?? I replaced the turn signal and harness and it was wroking fine until now. Think I may have moved some wires a little to hard when trying to get to the headlight switch? Any ideas much appreciated
you'll have to remove the steering wheel and look in the column and check out the turn signal switch. could just be a short, and hopefully you didn't burn any wires up too bad
