Any ideas?
  • Thread starter Thread starter other_shoe
  • Start date Start date Jul 27, 2008
O
other_shoe
313
  • Jul 27, 2008
My convertible top shop used sheet metal screws to install my boot channel, so now the proper screws -- it requires very short machine screws to avoid ripping the upholstery on the rear seat -- won't fit.
Is my best choice to find a larger diameter machine screw and tap new threads?
Or is there another option?
Many thanks.
66forfun
260
Pittsburgh
Jul 27, 2008
  • Jul 27, 2008
I found oversize screws for the tail light bezels, check with the parts houses there should be something out there.
BarnStang
1,260
Hagerstown, MD
Jul 27, 2008
  • Jul 27, 2008
Wow. THat's frustrating. You can try running a tap for the correct thread through. You might be surprised. As long as you can get a good hard bite when you tighten it, but if it strips, then you will have to tap to the next size OR drill and helicoil all the threaded nutserts. Not sure what they are really called...threaded inserts, small nuts stamped into sheetmetal...who knows?
O
other_shoe
313
  • Jul 28, 2008
Thanks for the suggestions, 66forfun and BarnStang.
Since the next larger diameter machine screw now fits in the whole -- albeit without proper threading -- I'm guessing I cant get the tap for the right size to work.
So I'll certainly check with the parts houses on a larger screw, though I'm afraid the head will be comically huge in this application.
I like the nutserts plan for a long-term solution. No idea how to do it, but I'm always up for learning.
My "It's Sunday afternoon and I have to get something done" solution was to use small, almost flat speed nuts on either side. Since there is not a lot of weight or force being borne by any of the eleven screws, this seems to work well enough for my current needs of not ripping the rear seat upholstery and not being reminded of the bad work.
izzy jr
76
Abilene,TX
Jul 28, 2008
  • Jul 28, 2008
That's always frustrating when you pay someone to do a job and instead of taking their time to get it right they just half arse it to get it out of the shop.
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Engine HELP - 351W Based Build Under Stock Hood
  • thinkfaster
  • Oct 17, 2024
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
M
  • mnky99
  • Sep 5, 2025
mnky99
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
