Any one with part# info or a 99' GT w/ traction controll please help.
TenaciousD
320
Tampa,Fl
1st off sorry if this is long but please hang with me
I just had the ABS module changed as the light was on and my traction controll was not working. Had a local shop put one in, the ABS light was off but the traction controll did not work still (traction controll name lit up when headlights were on but not the orange logo thing to show on or off, so im guessing its not the fuse)
took it back and they said when their computer was hooked up it showed no error codes and that the button was working when it was pressed on their screen so it must be a wireing issue if I wanted to pay more they could try and fix it.
Bottom line i think they have the wrong ABS part, what I want to know is where is the part # located on the ABS module, is it the Ingraved # on the top or the sticker with the barcode on the bottom. I have both # written down and the correct part number F922 2C219CA, mine do not match either so could there be another location maybe on the side i cant see. Thankyou for any help, i just want to cover my bases before I go down there and unleash hell.
the #'s stamped on a part are NOT part #'s but a stamping/engeering part # which can be crossed-over to an actual part #.
for a 1999 GT wth T/C the correct part # is F9ZZ-2C219-CA
Does your car have a chip or has the tune been altered anyway?
The ABS works right??
When you start the car, does the green spinning wheel traction control light illuminate for a second in the center of the gauge cluster??
