Any reason to get 180* t-stat over a stock t-stat for PI headswap?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Is there any actual 'con' to getting the stock replacement thermostat (195?) over a 180* t-stat when I do my PI headswap.
10.4-10.5:1 compression.
02 heads, intake, cam.
Would a stock one be fine? Just looking for a 'reason' to get the 180*?
180 is fine. Stay away from 160's.
If you don't command the fan to come on at a lower temp, changing the t/stat isn't going to do much for you. It may take a little bit longer to warm up, but once it's hot, it's hot. So you have to turn the fans on sooner to keep the temps down.
160 is too low. You'll wear the engine out and foul plugs.
yea but when changing the thermostat you are now changing your "normal" operating temp. The temp guage will still read in the same "normal" location as always, when the car is fully warmed up, and the computer will read "normal" now at 180*, just in reality your acctually running cooler. no tricks, no problems. theres no electrical connections to the t-stat itself, so why would it change anything?? as far as the pcm is concerned, it dont make a darn diff, so slower, no way! just retune the fans and dont go too cold because it even the 12* difference makes it take longer to warm up completely.. which is when the car runs its "new" best.
Have you ever heard off the coolant temperature sensor? I'm pretty sure that sends signals to the PCM :rolleyes: . You are NOT changing the "normal" operating temp buy using the 180^ T-stat. "Normal" for the computer is 197. If you change that, it won't run at optimum performance. Period.
This is true for older, non-fuel injected, cars. The PCM is calibrated to work best at normal operating temperatures. When you change the T-stat, you are tricking the computer.
The PCM will do what it does based on engine temp. It adds and pulls spark based on coolant and air charge temps. We can consider air charge temps to be a constant in this context. The cooler the engine coolant temp, the more spark your PCM will add, to the tune of (no pun intended) 1* of spark per 10* coolant temp. There's no tricking involved.
So, is that enough to go ahead and swap t/stats on a whim? Probably not. But if you're in there anyhow, you may as well go with the cooler t/stat, because it does pay dividends in the power catagory.
+1
This is the correct answer^^. The PCM adjust timing and fuel acordingly. In closed loop, hotter temps adds fuel and pulls timing, both of which degrade performance. Also keep in mind, that a 180* tstat does not mean you are going to run at 180 unless the weather is pretty cool. Also the tune that Kenne Bell shiped with their 1.7L kit was setup for a 160* tstat.
