Any tips or tricks to get a striped lug nut off?
Tire Shop has a special socket that will get it off. Its based off the same design as the Irwin Bolt-Grip extractors. They just put it on a Impact Gun in reverse, and it cinches down on the lugnut. They probably wont charge you a dime.
if they are the accorn style nuts you could always cut a slot into them. if you got one of those lug wrenches that has the flat point like a flat head screw driver at the end. that should work
