any tips to get reverse light bulbs out of the rear?
Use protective glove and get em out of there. If it breaks in the socket, there is a funny but good way to get them out of there by cutting a potato or something soft like that in half and sticking it over the broken bulb and turning. May sound weird but it worked for me.
well, i broke the first one...then i figured out with the second one that you have to push it in then turn it 1/4 turn. Turns out only one bulb had burned out, the other one was fine, but they're not working, so I've got a wiring problem somewhere.
Mine are the same way. It may possible be the reverse switch that gives the lights power when you shift into reverse. That's what I think it is on mine, at least.
I thought I had a wiring problem too, as the bulb was good. Turned out to be making a poor connection inside the socket. CLeaned it with electric contact cleaner and reinstalled it and it works fine. Try that before tracing wiring.
i too had this problem. My right rear indicator wasn't working, straight away i went to swap the globe. Couldn't get it out, i knew it needed to be pushed in and twisted but still no luck. I ended up breaking the globe it and pulling the metal casing out with some pliers. Then i had a lot of trouble trying to get the new globe back in, just didn't want to stay in, finally got it done after a few abusive words to my car. Got in my car and tried it out, didn't work still, checked the wires and it was a loose connection. Good lesson in that huh!
