Any used or know someone who has used the ethanol injection
GI Joe 97/02 said:
lol yea we been using it on the B52 since long before I came in the Air Force 21 years ago...lol...they love the water injection.........
are you a crewdog on a BUFF?
yea the airplane was a pitts special :D it could climb like a freaking elevator
I was a knuckledragger...went civil service still for the AF in Dec last year....
The Buff smoke black like a chimney when you throw that water to it.hehehe
i saw one leave from Luke AFB once and they must have turned the water on because it was BLACK smoke..one of the coolest takeoffs i've ever seen :)
I know a guy with the water injection.
He's got a 5.0 with H/C/I, stock lower end, and a vortech at like 10 or 12 lbs. The trick with water injection is timing. You have to really feed the car timing to take advantage of it. That's what it's for.
He's running :jaw: 32º :jaw: of total timing and makes like 498 rwhp with no detonation and no issues on a stock lower end. :nice:
GI Joe 97/02 said:
Results......likes/dislikes/lessons learned?
I have the 100 PSI kit from snowperformance. One issue was the hose from the tank leaked at the tank. The shop used clamps and better quality hose. Timing is set at 14 degrees. The car made 15 back to back dyno pulls with no pinging or loss of power/torque. The timing was raised to 16, still no ping. The instruction are to raise in 2 degree steps until ping, then reduce by 2 degrees. We didn’t do that, because I only wanted the injection for protection of ping (detonation). So until I get the engine forged it is used only as a backup. If the pump should fail, then the engine wouldn’t be damaged. I’m sure for those who want every ounce of power there is power to be made with it. I kept the timing at 14 degrees. I'm using 50/50 of water and alcohol [the rubbing type not drinking :) ]
Green: spaying, Red: tank is low.
http://img.villagephotos.com/p/2003-1/82254/gauges.JPG
Pump, tank, and controller
http://img.villagephotos.com/p/2003..._injection1.JPG
Engine bay
http://img.villagephotos.com/p/2003.../engine_bay.JPG
