Anybody have the Shelby Drop template & bit?
  • Thread starter Thread starter 69 Rustang
  • Start date Start date Apr 19, 2007
69 Rustang
307
Orange County California
Apr 19, 2007
  • Apr 19, 2007
Does anyone have one of the Shelby drop templates and drill bits that I could rent or borrow? I have a paper template that I could apply, but I don't want to be "off" when I do this as there is only one chance to get it right! I have drill bits up to 1/2", but as you know this needs to go 17/32". Are the 17/32" bits stepped so they fit into a 1/2 chuck?
Thanks!
R
RUSTYNUT
128
PDX
Apr 20, 2007
  • Apr 20, 2007
You can buy bits that have 1/2 shanks at most any hardware store. I would suggest getting a step bit for doing this. Start with 1/8 " hole and work with the step bit to closest to 17/32 and finish off with the 17/32 bit. If you have access to a drill press make your own metal template. Make sure you you use some lube and sharp bits. Test fit on your arm to sure it fits right.
2bav8
2,511
Mesa, AZ
Apr 20, 2007
  • Apr 20, 2007
I recommend a 1/2" drill bit as your final drill.
Trust me, you'll be OK.
Sicarius428
2,085
Apr 20, 2007
  • Apr 20, 2007
I used the paper template myself. What I did was cut out the original holes on the paper and bolted the paper to the shock tower. Then I used a punch to center where the new holes were going. From there I used like 5 or 6 bits and worked my way up to the final size.
Kevin
68rustang
1,537
Cleveland, OH
Apr 20, 2007
  • Apr 20, 2007
I tried that and It didn't work. Most popular hardware store will not have a 17/32" bit. You could also try www.mcmaster.com, not too expensive and quick.
1320stang
4,329
23
89
Edmond, Oklahoma
Apr 20, 2007
  • Apr 20, 2007
corpse made a billet steel template, pakrat has it now, but there's a line over at www.69stang.com
HistoricMustang
2,359
Confederate States of America
Apr 20, 2007
  • Apr 20, 2007
Agree! You do not want this fit to start out a little "sloppy".
HistoricMustang
67FBack
316
New Braunfels, TX
Apr 20, 2007
  • Apr 20, 2007
Paper Template
Forget that paper template for the second hole. Use the UCA mounting bracket to measure and drill the second hole.
Taranis
92
Austin, Texas
Apr 21, 2007
  • Apr 21, 2007
I've got the template that came with my TCP Coilover kit. There's a little surface rust on it, but it's straight. PM Me your address and I'll send it to you.
zookeeper
3,415
63
109
Rogue River, Oregon
Apr 22, 2007
#10
  • Apr 22, 2007
  • #10
If you drill your holes in the right place, it will work. Your UCA studs are 1/2", which usually measure about .495" or less, and all drills will drill slightly oversize, meaning a 1/2" drill will likely make a .505" hole, which is more than enough clearance. Worked for me...
J
Jimmys66
419
Paw Paw MI
Apr 23, 2007
#11
  • Apr 23, 2007
  • #11
You guys are wusses. I drew mine out buy hand.
The advice given me was :
1. check, recheck and check again.
2. center punch first. If the first hole is off it's all off.
3. check again.
4. start very small and then enlarge the drill bits to 1/2" checking in between sizes.
5. I used a small round file to clean up the holes a little and it fit perfectly.
zookeeper
3,415
63
109
Rogue River, Oregon
Apr 24, 2007
#12
  • Apr 24, 2007
  • #12
If being careful is being a wuss, then I must be. As a machinist, I know full well the meaning of "do it once, and do it right". If may just be two holes, but get it wrong and you'll be sorry for a long time.
Tim65GT
1,149
West Texas
Apr 24, 2007
#13
  • Apr 24, 2007
  • #13
Here is a jpg of the template:
http://i50.photobucket.com/albums/f315/Tim65GT/UpCrlArmRelocate.jpg
Just make sure when it prints, 1 inch is = 1 inch
J
Jimmys66
419
Paw Paw MI
Apr 24, 2007
#14
  • Apr 24, 2007
  • #14
I wasn't talking about being carefull. I was talking about using a template in order to ditch doing the layout. I was also just pokin' fun.
I tried using the paper temp. but, I just couldn't get it perfect. And yes, I wasn't making light of going it right. This job can be botched up in a very quick hurry.
I didn't trust someone else's template. I physically laid it all out myself to make sure it was PERFECT.
If you read the post you'll notice that I checked it, rechecked it and checked it some more so the only person to blame was myself if it was wrong.
J
Jimmys66
419
Paw Paw MI
Apr 24, 2007
#15
  • Apr 24, 2007
  • #15
Oh yea, I spent an hour in the first wheelwell making sure it was right before I had the sack to drill the first hole.
Besides nothing makes you look like a bigger moron than saying the words "Can you weld this up? I drilled it in the wrong spot."
Again just pokin' fun.
L
2012 Seats in 98 GT Convertible - pictures coming
  • lparsons42
  • Aug 11, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 17, 2025
lparsons42
L
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
65 Coupe I6 Auto to 302 EFI 5 Speed Swap
  • Scuderia
  • Feb 3, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 9, 2025
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
