Michael Yount
Mustang Master
Hissin - it may actually get a bit more complex than that for carbs. With the density decrease, the pressure differential that occurs between the carb venturi and atomospheric pressure is slightly reduced - which means slightly less fuel is pulled in than for the same volume of air being pulled in at a lower altitude. However, because of the density decrease, the MASS of air that gets pulled in at elevation is significantly less compared to the fuel that's being pulled in. Net result is they tend to run richer at altitude. Vehicles tuned to run at altitude with carbs usually have smaller jets installed to limit the fuel for a better match on a/f ratio. And of course, with less O2 and fuel going through the engine, less power is made.
Most of the overheating I've seen occurs on liquid cooled engines because 1) the engine's working real hard to climb the elevation change, and 2) the coolant boiling point is lowered because of the atmospheric pressure change at altitude - and once localized phase change occurs within the engine, things heat up quickly which causes more boiling - vicious cycle resulting in overheat. Not nearly as common in today's vehicles that operate with higher system pressures than years ago, and better radiators. Back in the day, they used to station big 55 gallon drums of water on the inclines (say in the Rockies) so vehicles could stop, let the car cool down, and refill the radiators. Of course, people used to not change oil per se - they just added it. Things have changed a bit.
