Anybody use a SN95 spindle on a classic stang with upper control arms?
1320stang
4,329
23
89
Edmond, Oklahoma
I was watching Saturday's episode of Trucks this morning before church where they're building a Ranger based Mazda pickup with the new 5.0 mod motor with a supercharger on it and a IRS.
Trucks! - Episodes | PowerblockTV
For the front suspension they're using FFR lower control arms, SN95 spindles and a pair of brackets that bolt to the top of the spindles that allow an upper control arm ball joint to be used. They used a Chrysler screw in ball joint with an unnamed ajustable upper control arm. The brackets ($299) were from Whitby Motorcars, a FFR builder in Greensboro, NC.
Whitby Motorcars
Recalling that the FFR cars use SN95 spindles from the donor car, yielded that FFR sells a uglier, welded bracket for $68,
https://factoryfiveparts.com/product.php?productid=16281&cat=255&page=1
Further FFR website research shows a UCA that looks eerily similar to the one on the show for $140/ea,
https://factoryfiveparts.com/product.php?productid=16251&cat=255&page=1
and their balljoint for $20/ea.
https://factoryfiveparts.com/product.php?productid=16252&cat=267&page=1
The biggest deal is that you'd have to go coil over on the shock, which may not be a big deal to some.
I was wondering if the existing UCA mount could be utilized while doing something else with the lower to eliminate the strut rod.
Don't beat on me too hard, it's been years since I've looked at the stock control arm area, I'd love for it to be some sort of bolt-on deal that wouldn't eliminate the stock mounting locations, but that's next to impossible.
I actually thought about this a while back, even going as far as getting sn95 spindles and the brackets. I've only gotten as far as mocking up the suspension (custom coilover, modified upper control arm, and opentracker roller lower control arm) using the stock spindle. I plan on seeing whether using the sn95 spindles would be possible this upcoming weekend. I'll post pics of my success or failure. Also, as far as front or rear steer; IIRC, fatman fab uses a modified sn95 spindle with the steering arm cut off and a custom bracket for rear steer application.
