Anylize my slightly better Dyno Chart
Pretty good numbers there. Like S/CBlack95GT said good hp though the lower RPMs. You dont want to get too much hp too fast though unless your running 16 inch slicks. Its why ill always think turbos over s/c for 1/4 miles. Turbo lag (as bad as it sounds) can save your ass in a race. 1st and 2nd can be a bitch to hold with high hp/tourqe at low. Turbos really kick you in the ass when you punch the top end of 2nd and 3ed so by then you wont spin your tires. Then again for SCCA racing a s/c is good for the low rpm/gear power. Its all about how you drive your ride.
S/CBlack95GT said:
The hp is still low in the RPM range, so that's a good sign. A more aggressive cam would of course gain more hp, but the driveability will fall a bit.
Yeah the crane said power from 1500-5500 so its doing what it said it would. I think when i get my tweecer next month i might be able to bring it up a little.
Whitedevil, longtubes are callin your name man! Also, richen it up a little bit up top.
wytstang, my friend is making 323hp/348tq with new edelbrocks on a 10.5:1 306 with ALL off the shelf stuff, nothing fancy under his hood and thats with junk shorty headers. The heads are milled and have a little bowl work but unported. He runs a comp 270 cam with a 1.7 rocker and a TFS street intake. All the power is under 6000 :cool:
actually form that dyno, your car would make more power a little leaner up top. moving form 13.4 to 13.5 this is if you are comfortable running that. If it doesnt ping, have at it. maybe try a tad bit of timing, then a little more fuel teh next pass at the track and see the effect on your runs and your mph.
