After I drive my car for like 3 or 4 miles my check engine light comes on. It will not turn on until I drive that far. I can then shut it off and the check engine light will remain off again for another few miles and then turn on.
I pulled the codes and fixed all the other codes but this one has me stumped. I have a 255lhp in tank pump, 24lb injectors, adj fp reg set at 39psi. I have a visible fp gauge in the car and my fp is constant all the time. Plus everything is new.
I keep getting code 91 which is (System running lean - Fuel control) My oxygen sensors are new bosch (I put less than 200 miles on them) I pulled the plugs and they everything is running right. The car runs fine no signs of a fuel problem when driving it but this damn code keeps poping up. I'm totally lost and about ready to take it to a garage already b/c I'm out of things to try. Anybody have a similar problem before. I'm thinking about upping the fp a little but not sure if that's going to help anything.
