  • 1994 - 1995 Specific Tech
anyone ever had this problem??
  • Thread starter Thread starter stockstang50
  • Start date Start date Jan 20, 2004
stockstang50
238
houston, Tx
Jan 20, 2004
  • Jan 20, 2004
Have you ever had your water pump pulley rub on the crank damper? I went out today to find a noise and it turns out that my top of the line hypertech pulley was the cause. But of course if you call Orielly's at 8:35 pm to get a factory pulley everything is a dealer part .
What would a possible solution be, short of buying a new set?
Ben
supersoniczex
446
Plantation, FL
Jan 20, 2004
  • Jan 20, 2004
how in the world is that happening? the water pump pulley should be in line with the crank pulley, not the harmonic balancer... so i don't see how they can be touching each other
you could upgrade to a romac balancer which is a little smaller diameter than the stock POS... but that's like $225 or so (although you should do it eventually, anyway)...
stockstang50
238
houston, Tx
Jan 20, 2004
  • Jan 20, 2004
From what I can tell is that the water pump pulley is too deep. I found out this was the problem when I removed the belt and started the motor. When it was running the two were rubbing to the point that the water pump was spinning. From what I can figure is that I need to replace that one pulley with one that isnt as deep.
I wish I could afford a romac that would be nice.
H
HazMat404
1,749
Jan 20, 2004
  • Jan 20, 2004
i had the same problem. it was just the lip of the water pump pulley those and ground off in about 5 min. still have a lip on there cause i know one is supposed to be there but i just had to shave off a tiny bit
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
E
For Sale 1989 LX Notch 410ci 85mm turbo 8 pt cage 9" rear end
  • EightyNineFive
  • Aug 22, 2021
5K
Fox Body Mustangs For Sale (1979-93) Jun 18, 2022
Freakinstang
F
M
Electrical 2011 GT vert. rear window problem/can bus gremlins
  • Matt19888
  • Jun 30, 2019
  • 2010 - 2014 Specific Tech
4K
2010 - 2014 Specific Tech Jul 1, 2019
Matt19888
M
