Anyone ever notice a difference in going from 9:1 to 10:1?
Aliate X
602
Rockland NY
In sound OR performance? My stock bottom is shot and my buddy has another one real cheap with some 10:1 pistons in it and new rods and a DSS main support and I was just curious if anyone has ever noticed a difference.
Compression = horsepower
Superchargers and Turbos increase compression which is how they make more power.
Yes, you will make more power but make sure to increase the octane in your fuel. 92-93 octane will be plenty.
As far as sound output, your car should have a bit more "bang" coming out the tailpipes. It will only be slightly noticable. I have an 85 with a little higher than 12.5:1 and you can feel it in your chest.
its my understanding that 1 point of compression will net you about 3% more power.
so according to this a engine making 300HP with 9:1
swapping to 10:1 will get you 9 HP, you now make 309 HP
swapping to 13:1 will get you 36 HP from the old 9:1
you would make 336 HP
the increase will result in... better MPG ( keep your foot out of it) more low end along with top ( compression will increase velocity into the engine = low end), the Cam will "hit" harder, the exhaust note will be louder and sharper.. and the hi-test gas will be a must. as for the amount of HP?? everything you have will be more efficient . hope this helps.. you cannot loose with high compression!!
Just me..............................
Thumper
