Anyone for a good mystery?
iLkYsPoNy
if she's a tranny then... well I'd do her.... it..
Well heres the scenario.... driving down the road on a dark night... SUDDENLY there is a slight to medium curve in the road! Oh no! Well, guess I should turn. Lalala... why not accelerate through the turn! YEAH!
Okay okay, enough with the story telling, I'm not very good at it. Anyhow, when I accelerate through curves, whether that be a slight turn of the wheel to an almost 90 degree... my volts drop, lights dim and the tach jumps UP and DOWN 500-750 rpms even though the engine never misses a beat. Once I'm out of the curve and back going straight all is fine. It also happens on occasion when hitting a bump ( but not all the time ). And usually when it's a bump, it's only the tach... the volts stay okay.
Any ideas?:shrug:
I'd go with what the first 2 responses were saying. Could be that when you're turning, either a connection is coming loose, or a bad wire is shorting out. I'm pretty sure there are some continuity tests you can do to test it.
The reason I said the ignition switch is because this is where the instrument cluster gets its power. What I'm guessing is that you are losing connection momentarily during turns and bumps which makes things flicker. The other thought I had was that during turns you are putting a more of a load on the power steering pump and the alternator is not performing as well, but this would not explain the symptoms of the tach or problems when hitting bumps.
Does this occur when you turn the steering wheel alone?
If not, any of the myriad suggestions above can be correct. Obvious checks of battery terminals for tightness are requisite as well.
Good luck.
