Pokageek said:That's the weird thing. I have a NEW Ford Racing 65mm TB that comes with all those components. This did not happen until I removed my smog pump though.
Pokageek said:I removed those hoses but maybe there is one still somewhere. I will check.
Pokageek said:I don't think you realize. I pulled all that **** out. I am pretty sure it was 9/16 bolts inthe back of the engine and then the exhaust tube on the h pipe.. I honestly dont remember anymore holes other than 2 sensors.
I will try this CMan, thank you.Pokageek said:Ahahah!! No I did not cap them. I thought they were sensors!I will try this CMan, thank you.
Awesome dude!! I had a feeling you hadn't capped those, or capped them properly. I thought I had gotten mine capped off good, but it turns out they had fallen against the header and melted them below the caps, so I had to cut them back and recap them. Good luck bro!!Pokageek said:Thanks. I used zip ties on them so they shouldn't hit the header. I was also wondering with my EGR leak, if that could cause surging..Hmm.. I wonder if that is considered in the category of exhaust leak or vacuum leak..or both?
Pokageek said:Cman, yo uare going to laugh at this one. I think when I put the new intake on, the fuel lines may have been interfering with the actual physical movement of the throttle cable causing it to do this. I will test tomorrow after I plug in my tweecer and remove the EGR.
LMAO, lemme know what you find.
