is there a set amount, or does the amount lost increase as the boost is raised higher?
heres my deal i cant decide between the novi 2000 or a kb. i know everyone here likes the kb, except gearbanger. i thought the paxton would be what i wanted, didnt think it was too much different. then i was reading some old post where TIM from mph said that from his experiance the kb bead centri in every way.
heres my problem. im going to get forged internals and want to run about 12 psi on pump gas. on the paxton im fine, but i dont think the kb 1.7 will be enough. i have heads and cams and will be working on l/t thurs.
so with the 1.7 i could go with the 14psi pully, but only make 9 psi. (dont know what i will lose). anyway i prolly wont get 12 psi from the 14 psi pully that the 1.7 tops out at. so then im thinking 2.2 kb. thing here is the price. on kb site it only says 5,400 not including other parts. with the other parts need, what does it wind up costing? also is the 8 rib set up a must?
i really dont know too much about the kb as i didnt plan on going with it. seems like alot of trouble (2.2) 1.7 would be easy, but im going to be maxing it out and prolly wont see the boost i want. can anyone give me some knowledge on the kb, are they harder to get running on pump fuel at higher boost? i think i will prolly wind up with the novi still.
i just dont want it if a 1.7 kb at 9 psi will beat me novi with 12 psi...you know?
