ok, been working on the goofed up wiring on a 70 mach 1 for a guy that had a performance engine/etc installed in it.
They had the msd ignition and cooling fan wired together and to a relay. I found out later why this is so. Somehow, the starter will turn on in the "ON" position so they wired the ignition and cooling fans together so you could flip them on, crank the car with the key and turn the key back off to still have the engine running...this is bad.
once I got the cooling fan and ignition rewired properly I discovered this problem. The starter will crank over in either the "ON" position or the "START" position. Once cranked and back in the "ON" position the starter will continue to run along with the engine which is bad. Something got goofed somewhere when these people went through the harness.
I thought it might have been the ignition switch itself so I replaced that, no dice.
I've been looking through the wiring diagrams that WORTH sent me and it looks like there should be a RED wire, RED/BLUE STRIPE wire, and BROWN wire going to the starter relay by the battery. I only have the brown wire and red/blue wires at this guy's relay. I'm about ready to just rip all the wiring out of the car and go over it...
anyone had any demons like this? also, if anyone has a decent camera and a 70 model...if they could snap some pics of the starter relay and surrounding area showing how it's all wired up that would be great too.
thanks guys!
thanks guys!
