Anyone know ARP Headbolts, Intake Bolts, Timing Cover, Main, Rod, Header Studs/Bolts
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Just curious if anyone knew any part numbers for any of these...whether they are bolts or studs and what year they work on:nice:
Headbolts
Intake bolts
Cam bolts
Timing Cover bolts
Header bolts
Main Cap bolts
Rod bolts
...and/or studs...
Headbolts
Intake bolts
Cam bolts
Timing Cover bolts
Header bolts
Main Cap bolts
Rod bolts
...and/or studs...
Rod bolts are worthless in stock rods..Upgrade the rods and they come with better bolts.
Stock intake bolts,cam bolts,header bolts,timing cover bolts are work great..I used the stock stuff over many times with no problems.
Headbolts use new stockers,using studs with the motor inthe car is gonna be a PITA..
Main cap studs/bolts will require a main hone to make sure the caps are 100% in the correct position.
Thanks for the info, but I was just looking for the part numbers, I'm not planning on using any...I would just like to have the info on hand.
