WaltA said:I did the Autometer swap too, and I must have had better luck than you. Mine works and looks just great. I am quite pleased with it.
The odometer mileage is stored in a separate little circuit board which plugs into the larger instrument cluster circuit board. As long as you keep your original odometer circuit board, you will keep your original mileage. This is very easy to do, and I am confused as to why those over in the referenced thread on Corral.net couldn't do it.
The car's computer has no idea what the numbers are, on the speedometer face. All it knows, is that (for example), it needs to put the needle at the 50% point for 80 MPH. That is correct for a 150MPH speedometer face. If you have, instead, swapped in a 200MPH speedometer face, the 50% point might be for 105MPH. So, you are actually going 80MPH, but your new speedometer will be indicating 105MPH. Of course, as originally pointed out, one could possibly re-program the car's computer but that would be some very involved and presumably expense undertaking.
i bet that cost a bundle of money. Where did you buy yours?
