  • SN95 V6 Mustang Tech
anyone know stock compression?
  • Thread starter Thread starter sleekkat232
  • Start date Start date Jun 2, 2008
sleekkat232
56
Spring Hill, FL
Jun 2, 2008
  • Jun 2, 2008
does anyone know where i can find the stock compression ratio for the 94-98 v6 mustang heads and the heads off of a 1990 supercoupe thunderbird? im looking to port & polish a set of heads i have laying around so theyd be ready to bolt on without any down time, but the heads i have a re in great shape off of a SC 3.8.
i realize the ratios are ultimately determined by the pistons too, but i guess im really looking for the combustion chamber cc's for each head.
thanks
racefan966
21
  • Jun 3, 2008
Ok here you go according to my mitchell on demand the Mustang 3.8 is 9.0 to 1 and the supercoop is 8.2 to 1. Hope this helps
J
jgt58
92
Knoxville,TN
Jun 14, 2008
  • Jun 14, 2008
If you sold those on either www.3.8mustang.com or www.v6power.com you could get enough money to buy you a set of spare stock heads. I wouldn't run that low of a compression as those are meant for a supercharged engine....
Mustang5L5
Mod Dude
Feb 18, 2001
43,264
17,952
224
Massachusetts
Jun 17, 2008
  • Jun 17, 2008
Yeah 8.2 is more or less suited for supercharged apps to reduce detonation.
I'd stick with the higher ratio as it will make more power.
Milton Questions, 351 swap newedge
  • 996stang
  • Jul 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 25, 2026
Killer351w
K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
G
Anyone Extrude Hone or Flow Bench Speed Pro Heads?
  • giddyup306v1.1
  • Mar 1, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Mar 29, 2026
2000xp8
Engine Raising compression on a relatively stock 302
  • keel
  • Jul 9, 2023
9K
Fox 5.0 Mustang Tech Jul 20, 2023
keel
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
