Anyone Know Where Pa Street Strip Vb Shifts?
Try being a lot more specific?!?
Yeah? Ok when I have the pedal to the floor and the butterfly valve on the throttle body is all the way open at what revolutions per minute will the crank be spinning when the transmission shifts from 1st to 2nd gear and then from 2nd to 3rd under the same conditions? After I made this post I emailed pa (wasnt quite as specific but they knew what I was talking about) and they said since aod is controlled by tv it will be same shift points as stock. Now I was also looking at a silverfox vb and he says his can change shift points. Now how is this possible if shift points are controlled by TV. He said his entry level can change points as well not just his constant pressure unit
