cb18201 said:i am thinking of getting some 4.30 gears, does anyone have them on their daily driver? also is there anything else besides the gears an gear oil i will need to buy to have them installed? thanks
Unless you want to replace all the wheel bearings and axle seals, I wouldn't buy the complete installation kit. It is a good idea to replace all those bearings and what not, but the question is do you want to spend the money to replace them. If not, a new pinion bearing and pinion seal will be plenty for the install. I believe the rear takes two quarts of gear oil, although I would buy 3 just to be on the safe side. Friction modifier is absolutely necessary. That is the "special formula" which lubricates the clutches in the posi traction.cb18201 said:ok so far on my list is : 1)ford racing 4.30 gears
2) either ford racing or ratech complete installation kit
with wheel bearings and seals included
3) gear oil (how many bottles?)
4) Friction modifier (how many bottles?)
anything else?
anything else?
Thats all the friction modifier you need. You still need the 3 quarts of gear oil too.cb18201 said:is a 4oz bottle of friction modifier enough for a gear swap?
