Jimp said:
Excellent! Can't wait to hear about that. You going with the 3.73s too? With that exhaust, gears and the locker, you should be well into the 14s.
Yes, based on pwrhws's work sheet, in regards to the torque spread throughout the powerband.. Then we have Scrmings run driven by Lidio with his 4.10's.. This all boils down to the 3.73's being the best choice for us..
The 3.73's should still place the 400RWTQ band close to the half track section of a 1/4 mile run.. I mean, in 3rd gear, you will still enjoy 400RWHP with the 3.73's, where as the 4.10's in 3rd gear will drop the torque into the 300RWTQ area.. Let me get the work sheet.. Stand by..
Originally Posted by pwrhws
--- As Tested At ---
PowerHouse Automotive, LLC
707 Main Street East
Girard, PA 16417
814-774-4966
--- Customer ---
Name :
Address :
Phone :
--- Vehicle ---
VIN :
License Plate :
Yr/Make/Model : 2005 / Ford / Mustang V6
--- Test Data ---
Filter Mode : FIR
Filter Level: 75
Engine RPM, Total Powe, Engine Tor
RPM, HP, Ft-Lbs
Run #, 1, 1
2700, ,
2800, 241, 439
2900, 242, 436
3000, 247, 433
3100, 250, 425
3200, 255, 419
3300, 260, 415
3400, 265, 409
3500, 270, 405
3600, 275, 401
3700, 279, 396
3800, 283, 391
3900, 286, 385
4000, 289, 380
4100, 291, 374
4200, 294, 367
4300, 295, 361
4400, 297, 355
4500, 299, 349
4600, 300, 342
4700, 301, 336
4800, 301, 330
4900, 302, 323
5000, 302, 317
5100, 302, 311
5200, 301, 304
5300, 300, 297
5400, 299, 291
5500, ,
Ok, so looking at this, you can see how a 3.73 setup should be able to still enjoy pretty close to 400RWTQ at around half track or more.. This is why the 3.73 gear car, could over power the same car with 4.10's at the end of the run.. Study the sheet, and you will understand what I mean..
Keep in mind, this worksheet was done with 4.10 gears..
So how you look at this is in relation to the 3600RPM mark.. We can also use 4th gear as a good measure.. We should be at half track in 3rd gear shifting to 4th.. This will drop the rpms down to less than 3600RPM... So at half track, you would really start to pick up steam with the 3.73's..
Also, for you Jimp, this is at the 75 Shot level.. LOL!! Dont get too greedy my man.. Hold some back! LOL!
