anyone running a TFS-R BOX INTAKE on a sn95
I would be more worried if you have the engine to back up the intake. The Box is like all others and it is a flat power band till about 3200rpm and it did not show any gain in torque till about 6600 rpm and we shut the car down and was 40hp less than the RPMII all across the rpm running 14psi of boost.
i have a 12.5:1 comp. 347, with fully ported canfield heads, 600" hydrolic roller from bullit, 1 7/8 kooks headers, 75mm TB, 80mm mass, and power pipe, and 200 shot of nitrous, i think that this in take will work well but maybe not, what do u think
I have a Downs Fords upper but its under a cobra R hood with 1/2" spacer. I think its taller than the TFS one. Not sure on that.
Mine would probably fit without the spacer under the stock hood. Considering it sits atop a GT40 intake.
Definately a high RPM intake.. comes on at 3500+
hmmmm. I wonder how high my hood is..
I'm really interested in the numbers you are going to put out. If I don't go turbo I will be upgrading to a T-trim with AFR 225's and a Dart 364
