Anyone running a x303 cam with trickflow heads on a stock 302
1. What size intake valves are in the heads?
2. Piston to valve clearance has more to do with duration than gross valve lift, so the .542 lift isn't as important as the duration, which as long as your valves are 1.94 or smaller, you shouldn't have a problem with as the X doesn't have a ton of duration.
3. Don't ever take anyone's word for it...ALWAYS do a piston to valve check before you bolt it together and start it without knowing. There are variances in tolerance in every part of an engine and you're mixing manufacturers. You don't wanna be the one guy who got just the right parts to throw together and bend your valves up because they were on one end of the tolerance scale.
trick flow
I called them to day and they told me that i could run the stage 2 cam too.
trickflow airflow twisted wedge 170 cylinder
Lift Value... Intake Flow CFM ...Exhaust Flow CFM
.100" ... 63 ..... 53
.200" ... 141 ... 107
.300" ... 205 ... 144
.400" ... 233 ... 171
.500" ... 251 ... 187
.600" ... 251 ... 193
