  • 1994 - 1995 Specific Tech
Anyone running torque box reinforcements w/ ABS?
  • Thread starter Thread starter go-stang5.0
  • Start date Start date Mar 15, 2007
go-stang5.0
2,244
Glenview,Il
Mar 15, 2007
  • Mar 15, 2007
I just bought some torque box reinforcements on ebay for cheap....don't know exactly why since I dont dragrace. But I thought it couldent hurt since my car sees open track events several times a year. Anyways, anyone find a nice clean way to relocate the rear ABS wires? I was thinking about taking a hole saw and cutting holes in the plates where the factory abs hole is. But I figure that may weaken the reinforcements...any other suggestions?
go-stang5.0
2,244
Glenview,Il
Mar 16, 2007
  • Mar 16, 2007
bump
go-stang5.0
2,244
Glenview,Il
Mar 16, 2007
  • Mar 16, 2007
no one?
94CobraPace
907
Houston, Tx.
Mar 16, 2007
  • Mar 16, 2007
Just my opinion, go ahead and do it. If you weld around the hold after you drill it, it should not weaken it too much. It would be better and stronger than not doing it.
Cobra4075
286
Tinley Park, IL
Mar 16, 2007
  • Mar 16, 2007
If I remember correctly, when I put my boxes in, there was still enough room to allow the wires to pass through. Using the hole that ford cut in the floor. The rubber grommet could not be used. My boxes were from wild rides if it makes a difference. The biggest pain was having to cut the torque box and bend it to get reinforcements in place.
go-stang5.0
2,244
Glenview,Il
Mar 16, 2007
  • Mar 16, 2007
Yea mine are from some west coast mustang shop laurel mountain mustangs or something like that and so they may be diff. from yours. I was thing the abs hole would line up with the center of the plate and I would just take a hole saw to everything but that may not be the case heh. I guess well see...btw what did you use to cut the sheetmetal down there, I'm wondering if my dremel w/ a cutoff wheel would be enough...or should I just take it somewhere and have the cutting done?
go-stang5.0
2,244
Glenview,Il
Mar 16, 2007
  • Mar 16, 2007
I guess I should have just welded up the torque boxes....that would prolly be fine for my application...but I bought the stuff so I'll put it on.
Cobra4075
286
Tinley Park, IL
Mar 16, 2007
  • Mar 16, 2007
The torque boxes a deffinately a good idea. You might not necessarily need them now, but down the road you might. I've more than a few street cars that severely damaged the stock torque boxes. I used a cut off wheel. After the install bend the metal back and weld the cuts.
blksn955.o
3,263
st.louis mo 314
Mar 17, 2007
  • Mar 17, 2007
I have the UPR lower trq box rein. and had no issue with the abs line. The issue was the size of the hole, I had to cut and bend the hole out bigger and like someone else posted bend them back in place (about 1/4in around the stock hole). I need to weld them so they dont look so tore up.
G
Integral power steering box options
  • GOvert
  • Jul 20, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jul 20, 2024
GOvert
G
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
For Sale 3-owner 1987 Mustang GT, $18K obro, Lancaster CA
  • Bill Cool
  • Oct 6, 2024
2K
Fox Body Mustangs For Sale (1979-93) Oct 13, 2024
nickyb
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
