I put some in my stang to try to drop the temp whilest running the a/c in this extreme Texas heat. Supposed to make the radiator water 'wetter' thus allowing more heat transfer. Anyone else tried this product? Any testimonials??
The problem with a 160* stat is that it’s to low. The stat will pretty much stay open thus not giving the water in the radiator time to cool down more. That’s why it's not recommended to use a 160*.chrismillion said:some people say that the thermostat will not make my car run right![]()
wytstang said:The problem with a 160* stat is that it’s to low. The stat will pretty much stay open thus not giving the water in the radiator time to cool down more. That’s why it's not recommended to use a 160*.
I always heard that the engine runs more efficiently when the ECU senses the engine is up to it's warmed up operating temp which is between 180-210* If the system is cooling the engine to get it down to 160* then it would almost be as bad as leaving the thermostat out- fuel economy, emissions, and overall performance will suffer because of being in open loop the whole timerevhead347 said:That is a myth. Once the thermostat opens it remains fully open. The orifice on a 160 and 180 are the same. Once they are open, they flow the same quantity of water.
The best thing I ever did to lower engine temps was to buy a Mr. Gasket high flow thermostat. Big difference, and is $8.88 at Advance or Summit.
Kurt
