Anyone using one of new dual disc clutches?
jdlatil
Gulfport, MS
Anyone using Ram, Spec, or McCloud dual disc clutches. I would like to know how well setup is working for you.
I have a new Spec 3+ set up but I thinking of not installing, really want the lightest pedal pressure.
Thanks
Jack
If you still have a relatively stock motor than you do not need a dual clutch set up, let alone the stage 3+ spec clutch you have. I am putting a stage 2+ in my car and I also have a kenne bell that is going in as well. I would reccomend that you get a stage 2 at the most for the setup you have and add the light pressure option which makes it just as easy as the stock clutch to push. I believe that option runs around $50.
