Snail50 said:my original thread keeps disappearing for some reason, so here's the link. Please read through and give your thoughts on what might be wrong.
THanks!![]()
http://forums.stangnet.com/showthread.php?p=4199669#post4199669
THanks!![]()
vrooom said:Did you change your display preference on the bottom left hand side of the page? (Display more that 2 pages)
What the GW tech support say about the UCA hitting the 17's?
You should definitely switch to stick-on weights. When I ran the 16's, I HAD to have stick-ons as the clipons would contact the arm. It might get you enough clearance???? As you mentioned in your other posts, 17's DO have more clearance than 16's, so this is kind of unusual....Snail50 said:THanks Bob. yours def. has good clearance; when my wheels are straight ahead, I have about 1/4", when they are locked they touch. I already gouged one of my wheel weights...probably need to have them balanced with adhesive weights. I put the original 14" rims & tires up front to avoid damaging anything, but the ball joint still rubs the tire very slightly.
That's correct!Anyway, you're running 17x8" with 5 1/8" B/S and Wilwoods. Did you got 5 1/8" to compensate for the additional offset produced by the Wilwoods?
I've heard they will give you an extra 1/8" in the REAR. Not sure if the front Baers have additional offset or not.I'm running AR 17x8" with 4 3/4 B/S. This week I will be installing a Bear 4 wheel conversion. Maybe teh Baers will give me a little additional clearance?
Nothing special for the UCA's. Had TONS of problems with the Granada spindles and bumpsteer, but the arms were an easy deal. I've installed a couple more sets since then, with no problems on those either.When you installed your UCAs, was there anything specific you did (other than follow the directions) to promote better clearance? I already adjusted my LCAs out as much as I could to get more negative camber, but it doesn't seem to help much clearance-wise.
