anyone with these cobra rims???
Other than the backspacing, it is exactly the same as the real Cobra rim. They should fit without any rubbing issues. Although I believe 245/45/17 is as wide as you can go upfront without a problem.
I put these on my 89. They fit great, but I went with the 97 front spindles (8mm wider than 94-95) The only problem I have found is the passenger side touches the lower a-arm when the wheels are at full lock right. No big deal though. Im going to go with tubeular a-arms anyway. But look for a better deal that that one! I got mine for $360 shipped to my door!! And for the tires, front was 245/45/ 17 and rear was 275/50?/17. Also I went with sumitomo tires from tire rack.com the tires were only $360 shipped for all four!
O- and for the rear fenders, I slamed mine with adjustable lower control arms and the tires clear everything fine, except the quad shocks. I just took them off. Hope this helps!
I have them in black. 245/45/17 up front and I have occasional minor rubbing with SN95 spindles. I would probably go with a 235 next time. I also hit the lower A arm at full lock when turning left on the drivers side.
In the back I have 315/35/17 Nitto DRs I don't think you'd fit any wider than a 275 though in any other tire. Quad were removed and the inner fenders clearanced. Have no problems with the outer fender. I did roll them, but probably didn't need to. Had more issues with the inners than the outers.
Mine fit great. 265/35/18 rear and 255/35/18 front, 26mm offset. Thats about the price that I paid for my polished 18's. So if you want the machined 17's they should be available much cheaper.
Do you have any pics from the rear?? would love to see:SNSign: them thanks
quick question.
Let me see if I have this correct. A wheel with 6.02 backspacing will set further in the fender than say a 6.11 backspacing. Just using real cobra rims and replicas for example.
