i use to have the same problem in the 98 (stock) it turned out to be the gas, so i just went to premiumADRENLN said:i get tapping when i go 3 quater throttle or morewhile driving while under the hood if reved while in nuetral i dont hear the tapping.
That I know of, none of the street grinds are creating PTV contact issues. The stock 18cc dish with the PI heads provides enough clearance for this. The only feasible way that I could see there being a problem, is if the valve springs weren't upgraded with the cam (if so required) and you're getting "valve float". In which case, you wouldn't have the issue very long, because if this were the case, it wouldn't take long at all to bend a valve. Whether you'd hear it or not under all conditions depends on how close the clearance is. Usually, with the engine not being under load is when it's at it's closest (IE: revving in neutral, or a missed shift). But as I said, in your case, I just don't think this is your problem.ADRENLN said:gearbanger, are you saying that with aftermarket cams you dont have to worry about ptv contact? i thought some people were havin problems with certain comp cams?
for the sake of the thread, lets say you do have ptv contact. would you hear it both driving the car and just recving it in neutral?
