Anyway to change gears with a 3 speed manual tranny?
  • Thread starter Thread starter brtnstrns
  • Start date Start date Aug 12, 2004
brtnstrns
606
11
Lewisville, TX
Aug 12, 2004
  • Aug 12, 2004
I'm in 3rd gear by about 35 mph with my manual 3 spd transmission. Is there anyway I can change the gears so i'm not changing gears so quickly?
65fastback2+2
1,229
Louisville, KY
Aug 13, 2004
  • Aug 13, 2004
if you arent getting on it, a c4 will go into 3rd by about 30mph. All you gotta do is change the rear gears. Jack the rear up and turn the driveshaft with your hands and see how many turns it takes to get the tire to turn one revolution. If this is 3 or lower you should be set. If its higher like 3.5 or so, you can change the rear gears.
D
D.Hearne
11,730
south louisiana
Aug 13, 2004
  • Aug 13, 2004
You'd have to have an extremely low rear gear to be in 3rd by 35mph. Something like 4.11's to do that. Yes you can change the rear ratio. What rear does it have? 8" or 9"?
65fastback2+2
1,229
Louisville, KY
Aug 13, 2004
  • Aug 13, 2004
its a 6 banger, prolly has the 7.X" one, w/e it is
G
geegee
2,015
near Oklahoma City, OK
Aug 13, 2004
  • Aug 13, 2004
Using numerically low rear axle ratios (2.79, 3.00) cause the tranny to feel longer between gear shifts. Conversely using a high rear axle ratio (3.55, 3.79, 4.11) causes the shifts to feel progressively shorter. Changing the ratio also affects the cars acceleration. Numerically low rear axles have poor acceleration compared to those with high numbers. Numerically low rear axles have relatively higher top speeds than those with high numbers. Its all a matter of what you want most. Installing a five-speed allows you to get the best of both.
T
tjm73
2,418
Rush, NY
Aug 13, 2004
  • Aug 13, 2004
What rpm are you shifting at? Even with 4.11's you shouldn't be in 3rd by 35 mph.
T
tjm73
2,418
Rush, NY
Aug 13, 2004
  • Aug 13, 2004
I just looked at your car's page (my eyes hurt! why do you have red writing on that blue back ground with white stripes? ouch my eyes).
It looks like you have about 26" tall tires. Is that correct? What size are the tires? What rpm are you turning at 60 mph?
65fastback2+2
1,229
Louisville, KY
Aug 13, 2004
  • Aug 13, 2004
ya he would, my c4 had 4.11's before and it would shift into 2nd just idling down the driveway at 5mph.
T
tjm73
2,418
Rush, NY
Aug 13, 2004
  • Aug 13, 2004
He has a 3 speed manual transmission, so he controls when it shifts into high gear.
65fastback2+2
1,229
Louisville, KY
Aug 13, 2004
#10
  • Aug 13, 2004
  • #10
ya i know, but im just saying 4.11's could be causing one to shift into 3rd at 35 mph.
T
tjm73
2,418
Rush, NY
Aug 13, 2004
#11
  • Aug 13, 2004
  • #11
At 35 mph with 26" tires he'd be turning just 1800-1900 rpm. Certainly not high enough to require a 3rd gear shift. 2nd at the same speed is only about 3250 rpm. Hell, 1st is only 5558, or about when he would shift to 2nd if he was really wringing it out.
He could go into 3rd, but wouldn't NEED to at 35 mph.
EDIT: this is assuming 4.11 gears
brtnstrns
606
11
Lewisville, TX
Aug 13, 2004
#12
  • Aug 13, 2004
  • #12
yeah unfortunatley I dont have a tach so I dont know how many RPMs i'm turning. But right now the 7 inch is in there, but I have an 8 inch ready to go in after I get it painted...i dont really wanna lose my acceleration, so if i have to deal with it its fine. I was just wondering if i could change it thats all
T
tjm73
2,418
Rush, NY
Aug 13, 2004
#13
  • Aug 13, 2004
  • #13
Yes you can change gears. 3.50's would be a nice road gear.
65fastback2+2
1,229
Louisville, KY
Aug 13, 2004
#14
  • Aug 13, 2004
  • #14
which is why you turn the driveshaft and count
ratio411
3,870
73
109
Pensacola FL
Aug 13, 2004
#15
  • Aug 13, 2004
  • #15
You really should post what gear is in the car now and what gear you put in your 8" that is going in...
T
tjm73
2,418
Rush, NY
Aug 13, 2004
#16
  • Aug 13, 2004
  • #16
Post your gear ratio and your tire size and I'll calculate your rpm's so you have an idea of what revs you are turning at several speeds.
M
4.10 gears = 200,000 miles ?
  • michaelleewebb
  • Apr 1, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 2, 2026
michaelleewebb
M
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Jun 14, 2026
Mindseye007
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
1965 289 xmission
  • sctang
  • Nov 15, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 30, 2025
Mcmahst
