AOD and 3.55 gear Question
85Vertible
41
The Wife has a 1993 LX AOD that we plan to install a set of Ford 3.55 gear into. Will I have to have the AOD shift points changed after gear install? Will the stock shift points work reasonably well with 3.55's?
Nope, no changed necessary. If anything the trans ends up shifting closer to redline where it should. It's much better than shifting at 4500RPM like it usually does with 2.73's.
I have 3.73's and the shift points are perfect with no mods
I think 3.55's are a great ratio. My brother runs them in his SN and i run the 3.73's in my Fox. There is almost no difference....except those 250 revs on the highway. I wish i would have went with 3.55's. you'll really like em
