T theautomatics New Member Dec 6, 2007 37 0 0 Chicago Aug 17, 2009 #1 Aug 17, 2009 #1 Is the AOD and AODE the same size? I wanna replace my AODe with an AOD but i'm hoping i wont have to replace the driveshaft and refit a new cross member....
Tubo(2-bo) Member Mar 25, 2004 279 0 16 Ft Walton Beach FL. Aug 17, 2009 #2 Aug 17, 2009 #2 The bellhousing on the AODE/4R70W's is 1in deeper, other than that they are externally the same. DS 1in shorter & Tranny mount to accomodate.
dodgestang Active Member Dec 15, 2003 1,360 0 37 Cecil County, MD Aug 17, 2009 #3 Aug 17, 2009 #3 Why are you 'downgrading'? You can also get an AOD rebuilt into an AODe case and then you can use the taller first gear too
Tubo(2-bo) Member Mar 25, 2004 279 0 16 Ft Walton Beach FL. Aug 19, 2009 #4 Aug 19, 2009 #4 Say Nick??? Did you get any comparitive times, on your, car stock AOD gears vs wide ratio gear set??
dodgestang Active Member Dec 15, 2003 1,360 0 37 Cecil County, MD Aug 19, 2009 #5 Aug 19, 2009 #5 Tubo(2-bo) said: Say Nick??? Did you get any comparitive times, on your, car stock AOD gears vs wide ratio gear set?? Click to expand... I've always had the 2.85 first gear (wide ratio) and 4.11 so no I do not have any comparative times.
