AOD and TV cable
  • Thread starter Thread starter beanplant
  • Start date Start date Oct 23, 2004
beanplant
548
KC MO
Oct 23, 2004
  • Oct 23, 2004
Okay, I've put an AOD in my car with the 306. We had to custom make a throttle bracket, and we also made it hold the tranny cable. How do you adjust/tune these? Should it be mounted somewhere specific? A specific distance? Right now it holds in some gears too long. Anything will help! Thanks!
-Shaun
Bad67MF
60
Sparks Nevada
Oct 23, 2004
  • Oct 23, 2004
Cable?
What cable did you use? You want this set right or you will burn up your trans. You may also need an adaptor for that Holley because it does not have the correct geometry. If it is holding the shifts to long that is better than shifting to soon. Let me know what cable you have and I might be able to help you.
DarkBuddha
2,215
Seattle & Tampa
Oct 23, 2004
  • Oct 23, 2004
The correct way is to set it using a pressure guage. You should be able to find instructions at either Lokar, Art Carr, or Windsor-Fox. Unfortunately, I just don't have access to my Lokar instructions right now.
Also, just to be clear, you want to mount the cable so that the cable moves an equal amount to the throttle. Try to mount it an equal distance from the center pivot as the throttle cable.
Hope this helps...
AOD TV linkage
  • Titanium90
  • Jun 10, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2025
KRUISR
1989 aod tv cable to bbk throttle
  • Creomod
  • Oct 4, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2024
Creomod
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
