  • 1994 - 1995 Specific Tech
AOD-E question
  • Thread starter Thread starter Sabio
  • Start date Start date Sep 26, 2004
Sabio
62
Germany,Berlin
Sep 26, 2004
  • Sep 26, 2004
recently I got a used Trans from 1995 with 50000 miles on it! It has the old style 1-2 accumulator from aluminum! The wearing of the bore wall is visible and I can feel the grooves with my fingertips!
Is this enough to make the piston leaking or can I switch to the new rubber style accumulator and everything is fine? I heard it is a little wider so sealing is better!
If I have to repair it what do you think about this kit?
http://www.transmissionpartsusa.com/ProductDetails.asp?ProductCode=400-07689001K
bjl95mustang
1,495
Austin,TX
Sep 26, 2004
  • Sep 26, 2004
You can use scotch brite pads to smooth the bores out then just use the rubber accumulator. Just make sure you keep it clean. There is alot of aode/4r70w info on www.tccoa.com under tech then tranny.
Dan95-5.0
1,110
Manitoba, Canada
Sep 26, 2004
  • Sep 26, 2004
what are some symptoms if you have a worn out 1-2 accumulator piston? i plan on doing the rubber accumulator when i do a trans go.
bjl95mustang
1,495
Austin,TX
Sep 26, 2004
  • Sep 26, 2004
You can see the wear marks.
Sabio
62
Germany,Berlin
Sep 26, 2004
  • Sep 26, 2004
symptoms are: very late 1-2 shift or no 1-2 shift,A shudder on the 1-2 shift!
Does anyone have the tolerances for the bore diameter?
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
2K
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
