AOD-E question
Sabio
62
Germany,Berlin
recently I got a used Trans from 1995 with 50000 miles on it! It has the old style 1-2 accumulator from aluminum! The wearing of the bore wall is visible and I can feel the grooves with my fingertips!
Is this enough to make the piston leaking or can I switch to the new rubber style accumulator and everything is fine? I heard it is a little wider so sealing is better!
If I have to repair it what do you think about this kit?
http://www.transmissionpartsusa.com/ProductDetails.asp?ProductCode=400-07689001K
Dan95-5.0 said:
what are some symptoms if you have a worn out 1-2 accumulator piston? i plan on doing the rubber accumulator when i do a trans go.
symptoms are: very late 1-2 shift or no 1-2 shift,A shudder on the 1-2 shift!
Does anyone have the tolerances for the bore diameter?
