AOD in 69 Mach 1
wyomustang
Tulsa
Just a few questions for thought. Putting an AOD in the mach 1. Just wondering a few things as I go. Like. What is the yoke I will need, is there a new part available. Is there a driveshaft length that will work or wait until the rearend is in and the transmission in. Just any AOD reference will help. thanks John
I;m going to see if the AOD yoke has the same bearings as the 68' in mine.
if not, you should[/] be able to find a shop in the area that can cut down and weld on your old driveshaft. That way the front has the right yoke for the AOD, and the rear has the right yoke for the rear diff.
although its very possible that the old yoke and the AOD yoke are the same. I'm finding out this weekend :)
WHY will you guys not LISTEN to me when i say MAKE YOUR OWN!!!
the cheapest mount out there that i could find was still in the $100 range...eh...too much.
I made a template for mine, and one afternoon, some 1/4" steel and a welder and i have a tranny mount for ~$20 at the most.
Don't understand how you made a transmission mount with some 1/4" steel and a welder for ~$20, most of them use a rubber mount of some type, ;) now if you meant a transmission crossmember than that is my plan.
Same as a C4 or a T5
Thanks, need to get that and the lokar bracket for the TV cable and I'll be about ready to tackle this project.
I have a yoke that fits the AOD. It has a ring around the base. It's a half and inch thick, and about 8" diameter. I don't know what the original app was, will this yoke work with that ring on it and what is it. A fly wheel of sorts maybe. Thanks John
