AOD Question
  • Thread starter Thread starter GearHd6
  • Start date Start date Jul 19, 2005
GearHd6
459
Ashford, CT
Jul 19, 2005
  • Jul 19, 2005
Hello, I just purchased a 91 Notchback 5.0 with an AOD tranny. In not familiar with this transmission so I was wondering if theres any way to hold it in 2nd rather than only being able to shift manually from 1st right to Drive? Thanks
M
Mopar1
61
Shelton, WA
Jul 19, 2005
  • Jul 19, 2005
Put a lentech VB in it
notchback
1,950
St Clair Shores MI
Jul 19, 2005
  • Jul 19, 2005
you can do it, btu it's not good for the tranny as it holds some intermediate clutches engaged when they shouldn't be.
start in 1, shift to "d" when you want it...then ds back to 1
this will hold 2nd (if you do it too soon, it'll ds, if you do it too late, it'll shift to 3rd)
then when you want 3rd...go back to "d"
but like i said...it'll wreck your trans sooner or later, and only cuts about a tenth off your et
it's called "the aod shuffle"
J
jimilane
158
Raleigh, N.C.
Jul 19, 2005
  • Jul 19, 2005
Yes
When you are ready to shift to second, move the shifter to "D" for about one second, and then back to first. This will hold second gear until you are ready for third. Then just shift to "D" for third.
This is the way I have shifted my AOD for three years now.
I have a transpac kit in mine to make the shifts quicker. It does a fine job. I haven't had problems with blowing up the pump or the overdrive band like everyone says will happen. The pan is always clean...
Jim
M
macx
228
SE Missouri near Cape Girardeau
Jul 19, 2005
  • Jul 19, 2005
Here's a few tips on making the trans last a little longer, esp if you're going to be driving it hard
http://www.lincolnsonline.com/article111.html
http://www.lincolnsonline.com/article80.html
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Removing speedo cable from the VSS
  • 91AOD5.0LX
  • Mar 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 25, 2026
91AOD5.0LX
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
