AOD Removal
its fairly simple.
place jack undertransmission.
remove driveshaft, shifter linkage and any other cables
remove crossmemeber bolts from the transmission and car
undo bell housing bolt ( start at the top and work you way down)
get someone to help you and slide it out and down.
and depending on your exhaust you might have to remove the X, H pipe. ( i didnt have to) make sure to unplug the O 2 sensor when doing this.
