AOD Shifter Handle
There should be a recessed screw with no head on the front (facing the CD player). If you feel around you can tell that it has an opening. You will need a small allen key wrench that will fit into it. Once you remove that you will have to twist and pull up on the handle. Be careful not to rip it off because the wire to the O/D button is connected to it.
