AOD shifting issues!
  • Thread starter Thread starter speedsterclone
  • Start date Start date Jan 3, 2010
speedsterclone
Northeast CT
Jan 3, 2010
  • Jan 3, 2010
Hi folks,
I'm hoping to get some guidance/opinions on my 89 5.0 w/ aod issues.
I bought the car as an unfinished project in summer 09.
There was alot into the car including recent transmission overhaul.
I was told that there was a B&M Transpak kit put in, and that the rearend was redone w/3:73 set .
The throttle kickdown cable was not hooked up when I got it.
The previous owner ran it that way for roadtests etc as he never registered the car after re-assembling.
I hooked up the cable and adjusted to specs but cant seem to get the shift that I want.
In drive the car shifts from 1st to 3rd missing 2nd entirely.It will kick down into 2nd when you stomp on the throttle though.
If I shift manually via the AOD shuffle I get 2nd but the 2-3 shift is sloppy unless I let off the throttle.
I thought maybe the gear ratio switch may have thrown of a sensor telling the car that its going to fast for 2nd thus the missed gear??
Any avise would be greatly appreciated...I have had a transmission shop play w/the throttle pressure settings w/ little or no change
apollo12
155
port st.lucie fla
Jan 3, 2010
  • Jan 3, 2010
What did the transmission shop say was the problem? and does the trans fluid have a burnt smell to it? and who put the kit in the trans?
ERM636
104
Sunny South, FL
Jan 4, 2010
  • Jan 4, 2010
Sounds like a bad 2/3 accumulator valve.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
