AOD speedo gear help
JohnVH
816
Lynden, WA
Hi all, I thank you for the help in advance,
I did a trans swap in my '93 and put a '89 aod in, I switched the trans speedo gear as it was different, but my speedo is 15mph fast at 60, and 5 fast at 25. Is there anywhere I can fix this, or what is my best option costing the least?
Automatic Transmissions with 7 Tooth Drive Gear
1983-1989 Automatic Transmissions
2.73 Gear Ratio / Blue 16 Speedo Gear
3.08 Gear Ratio / Gray 18 Speedo Gear
3.27 Gear Ratio / Tan 19 Speedo Gear
3.55 Gear Ratio / Orange 20 Speedo Gear
3.73 Gear Ratio / Purple 21 Speedo Gear
4.10 Gear Ratio / White 23 Speedo Gear
click on link below for more info. or to order speedo gears...
http://www.steeda.com/store/-catalog/speedometer.htm
Hi, Sorry for the late reply, didnt get a notice of any replies.. the 93 has the stock rearend so Im not sure... its a aod car stock so I have no idea.. BUT, I do know it has a blueish green speedo gear in there now.... This is the gear that came with the trans from the 89 car.
The stock range of speedo gears work correctly with a limited range of tire sizes.
See http://www.corral.net/tech/gearcalc.html for more help
Check to see if there is a speedometer shop in your area. If there is, ask about the Stewart-Warner speedometer gearbox. I believe it is either a 777 Series Drive Joint Kits and Parts or 666 Series Drive Joint Kits and Parts. It is a small gear box that fits between the speedo pickup gear on the transmission and the speedometer. It has quick change gears that allow you to choose almost any tire size and rear end gear ratio you want. This will allow you to get the accuracy with within 1%-3%. The drawback is that it isn't cheap.
Please excuse the typo (their's, not mine) in the following picture - it should read Custom ratio adapters, not Custom radio adapters.
See http://www.gaugeguys.com/ratioadapt.htm for more info.
