aod-T5 electrical help (won't start)
  • Thread starter Thread starter Ocalafox
  • Start date Start date Apr 29, 2005
O
Ocalafox
266
sunny central FL
Apr 29, 2005
  • Apr 29, 2005
Hey guys,
The mechanical part of the swap is done and now it won't start. I've read enough to expect this but not sure how to solve it. I have the t5 harness that mates to the two terminals on the case on order but not here yet. When I did the pedal swap I didn't remove any of the jumpers, still in the aod set-up (all three connectors). Obviously the harness at the transmission end isn't connected yet. Is there a way to jumper it to get it to start until the t5 harness arrives? Or is there something else that I'm not getting? Please help if you can. I'm reading all the search results but hope for a quick reply.
Thanks!
vann
ALMOSTFINISHED
315
Westchester County NY
Apr 29, 2005
  • Apr 29, 2005
If it doesn't even crank, (almost like a disconnected battery) I'd say that the neutral safety switch, (now the clutch safety switch) needs to be jumped. The car thinks that it is in gear so it won't allow it to start. You can use a paper clip or even better would be two male butt connectors on a jumper wire to complete the circuit.
Nick
O
Ocalafox
266
sunny central FL
Apr 29, 2005
  • Apr 29, 2005
Thanks Nick,
I'll try jumping it tomorrow. The chilton shows the t5 harness, I should be able to loop vack tow wires and put lugs on the two that hook to the terminals that are on the case.
vann
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
  • dan50
  • Jul 18, 2026
dan50
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
C
5r55s auto to TR3650 Manual swap 4.0 V6
  • Ceskz
  • Feb 24, 2025
  • 2005 - 2014 Specific V6 Tech
2K
2005 - 2014 Specific V6 Tech Mar 27, 2025
89ripper
