Aod To T5 Swap Having Trouble Help
89gt40lx
Orlando Florida
:shrug: :shrug: I HAVE THE AOD OUT AND I JUST WANTED TO CHECK THE STARTER TO SEE IF IT WORKS I REALIZED THAT THE STARTER HARNESS WAS DIFFERNT FROM THE 5 SPEED SO I HOOKED UP THE HARNESS FOR THE 5SPD BUT IT WONT CLICK STILL..WHATS HAPPENING?? I HAD THE PEDAL ASSEMBLY HOOKED UP ALREADY (5SPD) AND EVEN WITH THE AOD IN IT STILL I HAD TO PUT THE CLUTCH IN TO START CAR...BUT NOW THAT I HAVE THE AOD OUT NOTHING
You can run that switch to the inside of the car and hide if as an anti theft device if you like. I believe it will also turn on the reverse lights but best to wire that part in. In my car it worked with the auto computer, just threw every autotrans code it could think of.
What year model car do you have? I don't know of any AOD codes.
what if i push start the car will it start then....i had the tranny harness of a wrecked 92 gt that i had but the secretary here at my body shop threw it away??? does anyone know where i can get one??? everything went good (except the damn thing wont start)
thanks
I Agree, AOD and t-5 harness are the same. If your starter is different, then you have a new nigh torque starter from a 92-93. It will work but it requires you to totally rewire it to make it function. It's set up differently.
That may be why you can't start the car. Put the original starter back in and try that. It will work with the 5-spd.
Hang onto the hi-torque starter. You can look up what you need to rewire to make it work later on and do the conversion.
I'm thinking this is what happened.
I just did the swap in my car, it is older 86 coupe , but same principles apply and possibly wire colors. Under the car in the tranny tunnel area you have your origianl AOD harness that plugs to the tranny, which won't work with a manual tranny. So what you need to do is find out which wires are for the reverse lights, and which are for the Nuetral safety switch, ony mine they are red/light blue wire and a white and pink, you just jump those so that it thinks it has completed the circuit or run a switch in the car as mentioned above and use that, once the circuit is complete it will put the power to your starter solenoid and then to your starter when in the start position.
thanks
i bought that harness off of ebay and didnt even use it when i did mine. but im not using the clutch interlock switch.
