Aod transmission questions
Ajstone0415
ohio
so have a 5.0l with aod transmission. Had over drive go out go figure ha. Rebuilt trans and rebuilt valve body so everything moves nice and free. Installed and test drove to have it not coming out of first gear, while also making an abnormal chain like rattling/rotational noise coming from firewall area. Almost certain tourque coverter is trashed. So my question is since I have a 2 piece input shaft can I just install a non lockup TC without replacing the shaft. Also does that mean I need a non radiator cooler for it and just to drive it in 3rd around town and D on highway. Any thoughts would be appreciated
First, are you sure your tv cable is in proper order? The bushing is a known problem area and the first symptom is not wanting to go out of first gear.
Yes have the TV cable adjust correctly with a gauge. Added more fluid today just for giggles and got the thing to shift to second then the tc started rattling again so fairly certain its the Tc not pushing any fluid through
