Aode neutral grinding?
Bosko5.0
1,067
longwood, FL
I put into neutral then reved it to about 3800-4500 rpms let it drop to idle, and started hearing grinding/scraping noise in tranny area put into park noise stopped it only happens in neutral what would cause this?
Also is there a vent on the top of axle housing?
when i took out fill plug to check fluid a lot of air came out and it was very low.
The axle vent is on the passenger side of the axle. It was 12 bucks, special order, when I got one from the dealer. They can get pretty crappy and not vent too well.
Good luck.
I dont have the part # and I tossed the packaging. If you ask for the axle vent or axle check-valve, they should know what you want.
Good luck.
