Are all FoMoCo injectors that are blue 24#?
ratio411
3,870
73
109
Pensacola FL
I pulled some blue Delphi injectors from a 32v Lincoln "Intech" V8...
I also found Taurus Intech V6s had the same injectors...
Anyway, according to the color chart running around the site, blue is 24#, but the bottom of the chart has a note that says "Only Ford Performance Parts injectors follow this color chart."...
I know for a fact that the 460 EFI blue injectors are blue and 24#, and not aftermarket, so I assume these are the same???
Anyone know where I can find out?
Okay...
I googled this before posting and didn't come up with anything.
I tried again, and got this from Hemmings Motor News:
Ford
  • 1986-'95 Mustang with HO 302: orange-top, 19 lb./min., EV-1 injectors
  • 1988-'95 Ford Pickups with 460 and '93-'01 Lincoln: blue-top, 24 lb./min., EV-1 injectors
  • 1985-'88 Mustang and Thunderbird with 2.3-liter turbo: brown-top, 36 lb./min., EV-1 injectors
  • 1999-'04 Ford Lightning Trucks with 5.4-liter: green-top, 42 lb./min., EV-1 injectors
  • 2000-'02 Ford Contour with 2.5: pink, 21 lb./min., EV-6 injectors
  • 1999-'02 SVT with 4.6 liter DOHC and '00-'02 Lincoln Navigator: blue, 24 lb./min., EV-6 injectors
GM (Rochester and Delphi units are not color-coded like Ford)
  • 1985-'86 Camaro with 305: 19.3 lb./min., EV-1 Rochester injectors
  • 1986-'88 Camaro and Corvette with 350: 21.6 lb./min., EV-1 Rochester injectors
  • 1997-'98 LS-1 engines: 25.2 lb./min., EV-6 Bosch injectors
  • 2001-'04 LS-6 engines: 25.5 lb./min., EV-6 Bosch injectors
  • 2001-'03 Chevy and GMC trucks with 6.0 liter: 22.1 lb./min., Delphi EV-6 type injectors
Looks like I am going to be pulling the injectors from all the Intech V6 Taurus engines at the upull... :)
The Lincolns I got were EV1 big body injectors with the single pintle.
One of the Intech V6s had blue EV6 bodied injectors, with 4 hole pintles, and EV1 plugs.
Maybe I can find 12 of those, and end up with 8 strong injectors from the bunch...
I was hoping someone would say that! ;)
I just want to keep a stockpile to feed the needs of four 5.0 engines!
Every now and again these used injectors go out, and I like to keep a supply of spares.
Fuel injector sizing & injector photos
Revised 11-Dec-2011 to add larger injector sizes to injector table
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines at the flywheel.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
36/.5 = 72, 72 x 8 = 576 HP
42/.5 = 84, 84 x 8 = 672 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
19/.5 = 38, 38 x 8 = 304 HP x .85 = 258 HP
24/.5 = 48, 48 x 8 = 384 HP x .85 = 326 HP
30/.5 = 60, 60 x 8 = 480 HP x .85 = 408 HP
36/.5 = 72, 72 x 8 = 576 HP x .85 = 490 HP
42/.5 = 84, 84 x 8 = 672 HP x .85 = 571 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
Here's the duty cycle explanation. Duty cycle is how much of the time the intake is open the injectors are turned on. The 85% figure means that for 85% of the time the intake valve is open, the injectors are spraying. The idea is that you want some percentage of the duty cycle left over so that you have some room to grow the process.
If you are at 100% and you need more fuel, all you can do is turn up the fuel pressure. That means the whole fuel curve from idle to WOT is affected. Maybe you are already too rich at idle, and turning up the fuel pressure makes it worse. If you had some injector duty cycle left to play with, a custom tune could use that where it is needed. That would not over richen the whole range from idle to WOT.
If you did turn up the fuel pressure, you might be able to change the injector duty cycle to get the air/fuel mixture ratio you want since the injectors will have extra fuel delivery capability.
With larger than stock injectors or higher that stock fuel pressure, you will need an aftermarket MAF that matches the injector size. The MAF “lies” to the computer to get a fuel delivery schedule that meets the engine’s needs and isn’t too rich or too lean. The best strategy is an aftermarket MAF and a custom tune to insure the best air/fuel ratio over all the RPM range.
Don't forget to increase the fuel pump size when you increase injector size or significantly increase the fuel pressure
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
