Matty22 New Member Feb 16, 2007 10 0 0 Greenville, SC Mar 22, 2007 #1 Mar 22, 2007 #1 I'm pretty sure they are but wanting to make sure. I got a NIB set of what should have been 3.55's off ebay and the ring and pinion both have 308 stamped on them. Just want this confirmed for when the guy trys to give me crap about it. Thanks.
J javier302 New Member Nov 8, 2006 48 0 0 Mar 22, 2007 #2 Mar 22, 2007 #2 count the teeth on the ring and on the pinion and let me know i believe my pinion said 4.10 on it... i don't remember about the gear. post the count #'s
Matty22 New Member Feb 16, 2007 10 0 0 Greenville, SC Mar 22, 2007 #3 Mar 22, 2007 #3 ring-40 pinion-13
bigcat start with the upper hole, and if more traction is May 1, 2005 3,015 1 79 7200 feet Mar 22, 2007 #4 Mar 22, 2007 #4 40 divided by 13 = 3.0769 ~3.08
J javier302 New Member Nov 8, 2006 48 0 0 Mar 22, 2007 #5 Mar 22, 2007 #5 by math, they are 3.08 my ring was 41 and my pinion 10 if u devide the ring by the pinion u get the ratio.... if anyone has a 3.55 could you count the teeth to verify, thanks
bigcat start with the upper hole, and if more traction is May 1, 2005 3,015 1 79 7200 feet Mar 22, 2007 #6 Mar 22, 2007 #6 javier302 said: by math, they are 3.08 my ring was 41 and my pinion 10 if u devide the ring by the pinion u get the ratio.... if anyone has a 3.55 could you count the teeth to verify, thanks Click to expand... dividing the ring count by the pinion count tells you ratio, no matter what ratio they are.
Matty22 New Member Feb 16, 2007 10 0 0 Greenville, SC Mar 22, 2007 #7 Mar 22, 2007 #7 Thanks for the help guys.
J javier302 New Member Nov 8, 2006 48 0 0 Mar 22, 2007 #8 Mar 22, 2007 #8 yeah bigcat, but i figured if someone had a 3.55 set matty22 would know the amount of teeth that the ring/pinion needed to be...
bigcat start with the upper hole, and if more traction is May 1, 2005 3,015 1 79 7200 feet Mar 22, 2007 #9 Mar 22, 2007 #9 oh, i see your point now i must have missed the obvious.
